cwe123
- Jul 24, 2012
- 20
Hello,
I have a 2000 Sea Hunt Escape 200 and am dealing with an issue with water in the fuel. I am replacing the sender gasket soon to rule that out. I have a plastic Perko combination fill and vent, I have confirmed that the vent from the tank is connected to the vent on the fill unit. It functions normally as far as I know, no issues with the vent as the motor takes fuel fine etc. The fill works also, I can pump at full speed and when it gets full, some fuel comes out the vent hole.
I have tested the fill for leaks by putting paper towel in the fill tube right under the gasket and went at it with a hose. The paper was dry when I opened it up. Side question, how does the 'sealed' vent actually vent?
I have another thru-hull mushroom vent on the hull under the fill, and I can't see the inside as there's too much foam in the hull. It definitely gets wet when I'm running the boat - I shot water at it with the hose and water flowed back out. Does anyone know what this vent is for? I'm thinking of putting a clamshell on top of it just in case.
Thank you for any insight, it's much appreciated!
IMG_3750.JPG I have another thru-hull mushroom vent on the hull under the fill, and I can't see the inside as there's too much foam in the hull. It definitely gets wet when I'm running the boat - I shot water at it with the hose and water flowed back out. Does anyone know what this vent is for? I'm thinking of putting a clamshell on top of it just in case.
IMG_3751.JPG Thank you for any insight, it's much appreciated!
