sea foam
bsandy565656
I have a 48 hp evinrude that dies out in idle. How to use sea foam is my guestion. Heard it is good stuff and can't hurt useing it. Thanks ahead of time....... bsandy.....
pscrabber59
Re: sea foam
Seafoam is a gas additive so just read the directions and mix with your gas mix.
In your case seafoam might not be the solution to your problem, it sounds like a carb. related problem(idle adjustment, carb. cleaning) Try the seafoam and see how the motor idles.
Gd. luck
eclark53520
Re: sea foam
Its worth a shot, but Sea-Foam is not the be all end all of carb problems.
If it works, great, if not, you're going to have to open up those carbs and get your hands dirty.
wilde1j
Re: sea foam
Sea Foam doesn't do a thing for cleaning carbs. It is for decarbonizing the internals of a motor.
pman7
Re: sea foam
Do you advise against running a tank with some B-12 through your motor? Maybe I've imagined it but I've always thought my 59 Evinrude trolled better after running B-12 through it about once a year.
ezeke
Re: sea foam
I agree with wilde1j as far as cleaning the carburetors. If you want to clean the carburetors you will need to remove them and use your cleaner full strength. You should try not to run IPA or Naptha on your rubber gasoline fuel lines in strong solution.
