Re: Sea Doo XP's good skis?
My 98 XP has been bullet proof. It's over 10 years old and I have never had any problems with the engine. The only thing I've had to do to it maintenance wise is clean the carbs every season. I still have 130 compression in each cylinder and it can still run with the best of them. I think the reason that mine is still running great and others have had problems with them is because I maintain it very meticulously. A lot of people just gas and go and that doesn't work with a performance ski. If you ride it like I do it will get wet and you will occasionally get some water in the engine bay. (It can come in through the vents on the hood of the ski) You need to be aware of that and know how to get the water out and what to do if somebody flips it over and floods the engine with water. If you take care of it an XP can be a reliable ride.
hmm..your very lucky then. I maintain mine very well, but i sure as hell don't baby it much. It's a toy, there meant to be abused and have fun with. But, im hard pressed to believe there reliable. Esp. once water comes over it when your barreling threw a 5 foot wave....(front ends on these are exceptionally heavy, so there tendency to nose dive is great, which is when you suck the water in.) Everything eles ive never had to replace...other then engine failures prematurely due to the exhaust pipe splitting open from all the bouncing..(even with the factory seal, the bolts are not thread locked from the factory, they will break lose and back out).
To avoid this issue, i'd recommend removing the pipe, adding thread locker (red) to the bolts, and put some exhaust gasket sealer on both sides of the gasket. Ever since i did that i have never had an engine issue.
