Sea Doo Problem
ropers44
I have a 1995 Sea Doo Bombardier that will start and idle up on land but will chug and die in the water. The thing was running fine until the grands took it out and returned it broken, any help would be appreciated. I will add that it will occasionally idle up and run but will chug and die after you power down. The plugs are new.
Brian 26
Sounds like you need to rebuild the carb(s) and replace the fuel lines. I realize fuel lines sound odd but internet search seadoo grey fuel lines and you can read all about it. The Achilles heel of this era of seadoos
