I have a 1992 Sailfish 190 Sport offshore fishing boat that has two scuppers on the transom. They are the typical rubber flap scuppers that should not be below the waterline. But due to the weight of my engine they are below the waterline when my boat is in the water. When two people stand in the back of the boat water floods in through the scuppers and back onto the deck through the deck drain holes with this scupper type. I have had the scuppers replaced twice but the problem still occurs so it is not the actual scuppers themselves. I need a scupper that will seal tight enough to not let water back in. I am looking into two designs of scuppers now: a duckbill scupper http://www.thmarine.com/product.cfm?PRID=189 <br />and a sea scupper http://www.boatersworld.com/product/712181.htm. <br />Which design do you think would seal the water out better? Has anyone had any personal experience with these two designs and if so did you like them or not? And if you had any other suggestions or scupper ideas or designs please tell me about them.<br /><br /> Thanks,<br /> Ben Fredericks
