Scuffs on Blue Gel coat?
Bayliner245
I'm getting a lot of scuffs from my fenders on the blue gel coat! If I rub real hard I can get the edges off a bit. Is there something out there that I can apply that will take it right off (I'm guessing I should wax after that)? Thanks!
gcboat
Re: Scuffs on Blue Gel coat?
Try some very light grit rubbing compound first. If it works then yea! If not go a little heavier with something like 3M Finesse II -. Swing by your local body shop and try and buy a small amount from them. Waxing is mandatory after the compound. :D
