As you all know I just got my merc 650 1975 3cylinder outboard motor running. I have not been able to put the motor on a boat or in a test tank yet to continue on with the final adjustments but I have been keeping it running from time to time to keep the carb work in good condition. After I shut it down then turn the flywheel by hand I hear something like a scrubbing or rubbing sound. Almost like the sound of a balloon when you twist it or rubb it with your hand. Does this make sense and is this normal?<br /><br />Also, I know I have not been able to do all the adjustments since I am unable to put the motor in water, do these motors tend to idle a little rough? It's not unbareable but I wish it would be smoother than it is.
