Schematic - Evinrude V4 Power Tilt
RonWhitt
I have a 1979 Evinrude 85HP for which a power tilt was later added. The motor and power tilt was installed on another boat and I'm attempting to install it on my Skeeter bass boat. The power tilt motor mounts inward between the motor mount brackets. I need a schematic in order to wire the motor.
Hooty
Re: Schematic - Evinrude V4 Power Tilt
The Clymer manual has two schematics. One with a fuse and one without. Which one is yours?<br /><br />c/6<br /><br />Hooty
Dhadley
I dont want to step on Schematics toes but he will need to know if you are using the two wire motor with relays or the three wire motor with a solenoid. <br /><br />Just a little more info!
RonWhitt
I have a three wire motor, but it did not have either a solenoid or relays, so I don't know which it uses.
Dhadley
The 3 wire uses the solenoid deal. Or you could change the electric motor to a two wire motor and use the relay set up (which is newer).<br /><br />Good luck!
