Scheduled maintenance for 5.0L MPI 260 HP Mercruiser/alpha
glove
I have a 3 year-old Crownline bowrider, with a 5.0L MPI 260 HP Mercruiser/alpha.
At 20 hours of use on the motor during the first season, I had the following recommended service performed on it($375)
1) lube, oil and filter
2) outdrive fluid changed
3) belts/hoses adjusted
4) u-joints lubed
5) R&R outdrive and alignment check
The boat finished its third season last summer (~130 hours) without any further maintenance.
The shop is recommending:
1) tune up (replace cap, rotor, plugs, check/adjust engine -- ~$450)
2) Replace water pump (~$300)
which they recommend every 3 - 4 years (it's now been 3 years).
Would it be foolish to wait until after the 4th year instead of having this maintenance performed now at 3 years?
Thanks very much
Don S
Re: Scheduled maintenance for 5.0L MPI 260 HP Mercruiser/alpha
3 years in salt water is about max that I recommend to customers on an impeller. Tuneups I recommend yearly, especially if they set through winter in storage and have been fogged. Just to get the best milage out of those fuel dollars.
glove
Thanks, Don. I'm purely in freshwater.
I appreciate your advice.
ziggy
you could go to the adults only sticky at the top. find your service manual and load it up. in it you'll find a maintenance schedule as to what needs service and at what intervals...
