Scared Myself
TwoBallScrewBall
OK so I'm out fishing today, and it's the fourth time I've been out on the same tank of gas. Gas guage does not work right, has read almost full when I have pumped 12 gallons into the 25 gallon tank. Anyway, I got done fishing (did good too, 3 good stripers, a blue, and a skate in about an hour) and I'm getting ready to head back. I switch on the blower, then walk up front and pull the anchor in. I get done with that and flip the ignition switch on and hit the starter button. Fires then dies. Hit it again, fires then dies. I did this about three more times and get to worrying, and that's when I notice that the fuel guage is at DEAD EMPTY. Now I panic. Great, I'm going to have to get towed in. I sit there for a minute and then realize that the ignition switch is off. I must have bumped it. My boat has no keys (lost over the winter) so I have an on/off switch wired for the ignition and a push-button starter switch. It's trailered only so I'm not worried about someone driving off with it. :) Somehow I knocked the switch off while pushing the button. It was firing while the starter was cranking, but as soon as I let go of the button the ignition would go dead. <br /><br />I flipped the switch, the fuel guage slapped back to "F" and she started right up.<br /><br />Got on the trailer, filled the tank, only took 8 gallons after 4 good fishing trips and some cruising. Gotta love that 3.0. :)
brother chris
Re: Scared Myself
Don't ya love panicing out in the middle of a lake/ocean when no-one is around and things aren't working out right. :eek: Been there, done that. <br />At least you had gas to get home. <br />Get a new gas guage. If ya don't, you are definetely going to go through that again. :(
TwoBallScrewBall
Re: Scared Myself
Yeah I have to do some diagnostics on it, with my luck it's the sender or the float. Couldn't be as simple as needing just a new guage!
oddjob
Re: Scared Myself
I would get a stick as a spare and second opinion.
TwoBallScrewBall
Re: Scared Myself
Nowhere to 'stick' the tank. It does not even have a mechanical guage on it as I thought was required. I'm going to pull the sender/float this weekend and play with it.
