First I apologize if this is not the right place to post this as I seem to have difficulty navigating this site. I just installed a 2008 Merc 300 on my boat (used) and it came with two smartcraft gauges. One Tach, one Speedometer. The Tach I can just barley read the digital readout and the Speedometer I cannot read at all. Shining a flash light on it I can almost make out what it says. I've got the both contrast set up as high as it can go as well as the light. Is this normal or are these gauges N/G? Also the engine hour reading has not moved after 3 hour of run time. And lastly I understand that the Speedometer has a fuel gauge in it (the boat yard remove the old gauge I had and did not reinstall it). I'm a bit confuse as to how it works since it does not connect to the fuel tank sensor (at least not what I can read). The boatyard (that installed the motor and gauge) said to fill the tank and set the gauge for how much fuel the tank held and then it would deduct the burned fuel from the total. It you do not fill your tank each time how do you keep track of how much fuels is in the tank?
Before I buy replacement gauges i want to know if it is worth the money if I still can not see the digital read out.
