fisheymikey
- Jul 30, 2012
- 450
force 125 1988
I have read numerous reads in regards of resistance my engine should have 500-800 I have 768 on both cold engine but after it runs and engine warm it spikes to 1000 then goes back to 768 is that normal?
but more important when I take reading while engine is idling at 1500rpms the output of the voltage is VERY unstable...
I put my voltage meter to both setting i.e dc and ac and im not getting 180 volts as per outboard ignition states...
I get numbers like 10-50-10-0... my logic tells me how can moduals work properly without a steady stream of energy and that might be the proplem since the beginning.
the engine does start easily but think that's why I don't get my full 5500 rpms I only get around 4300-4500
I have the right prop and have done the link and sink
I just want to put at ease that the stator is or not the issue
I just read I guess I need a dva adaptor before I take the flywheel off again
thanks
mike
thanks
mike
