Hi,
Just purchased a Larson 250 Hampton 1997,with a 5,7 merc/Alpha one (300hours), to have as a winter project. The boat was really cheap with a siezed engine (PO says it does not turn w/o plugs when trying on the crank with a ratchet) due to saltwater intrusion from a rusted out exhaust mainfold and has been sitting for about a month with water in at least 1 cylinder.
I?m use to restoring engines and not put of by this, the question is what level of repair to expect:
1. Change mainfolds/risers pour rust solvent in rusted cylinders, change oil and try to rotate engine
2. Pull the head right away to inspect the damage, pour rust solvent and tap lightly on siezed piston/pistons
3. Lift the engine out to do a complete restoration with a rebore.
In your experience what is called for here of the above?
Going to collect the boat on saturday...
