Re: Saltwater Fishing with Freshwater Boat?
Tahoe Q5 is a bowrider, 19'5" long, 91" Beam, V6 220 hp Merc I/O, 16 degree deadrise, 18' draft, approx. weight w/engine 2363. I have been in the Gulf when it was as flat as could be from PCB to Destin, I also have been out there in a 23' cuddy that the water would occasionally splash over the bow. The trip in the 23' was from Crystal River, that was a nasty day. It was too rough to go to where the fish were at then. We turned around and came back toward shore, fished a little but no fish. The Tahoe is not a boat to put out in open water unless you really know what you are doing and have checked the weather real good to make sure it is going to be calm that day, Gulf or Atlantic, the Gulf can go from smooth to nasty in a heartbeat. If you are going to try to go out see if you can find an experienced boater to go with that knows when to go and when not to go, or, when to run for shore quick. I am in SE Ga, there are artificial reefs that are about 12 miles off shore, there are other places that are closer to shore but you still have to go quite a way from an inlet to protected water and you are even farther from a place to get out of the weather. The sounds can get a 3 to 4 foot washing machine chop, which you can handle in your boat, just not a good ride, it will be a wet ride if you are going into the wind, check my boat info in my signature, I know all to well how the water is in the sounds and rivers here. As to the saltwater use, the water will not make your boat disintergrate, you do however need to flush the engine out real good after use. I boat this water all the time, I flush about 20 min, and now use Saltaway as the finish of the flush, after an outing which could be a day or a weekend since I live on the water and have a dock. Wash the trailer real good and wash the boat real good after each use and you will be fine. There are also a lot of good fishing spots inshore as well without having to go outside and you can catch some nice fish, or find a nice beach to anchor and relax on.
