Salt away
Damo 1
Just wondering if anyone is using Salt Away flushing agent at all, i would like some feed back if people are trialing or have been using it..
Home Cookin'
Re: Salt away
In previous discussions, several people use it and think it does some good but who's to know. others suggested some house hold items like soap IIRC to accomplish the same results.
I think that if you're going to get the salt/corrosion out, it will be with fresh water. Consider, though, that every time you stop your engine, say for a picnic or overnight, the residual salt water dries against the hot metal parts. whether running or flushing, your next restart isn't going to scrub off the dried surface but so much. So flushing at the ramp after a weekend in the salt water can only do but so much for the residue. it does, however, clear out the most recent salt water and replace it with fresh in little nooks and crannies--the engine drains naturally.
True, a fresh water motor or a regularly flushed salt motor will look better inside when its 15 or 20 years old. I'd be more concerned about the external parts.
Flushing engines is a relatively new practice. People have and still do run motors in salt water for years without flushing. One of mine, for example, is moored with no fresh water source so it only gets flushed a few times a year. Another I flush after a few days in sea water and sand/mud when I pull it up but not every day. Makes me feel better. Can't say how much difference it makes on the 23 year old motor.
F_R
Re: Salt away
As just said, it makes you feel better. Same with the salt removal products. Snake oil.
Water is the solvent for salt. Put some table salt in a pot of water and you will see. Put too much in and it will reach a saturation point where no more will dissolve. Sea water is nowhere near that saturation level.
Engine344
Re: Salt away
We use Saly Away on snow plows, not an internal application however we have seen improvement in year to year maint. (With Salt Away in-line with our hoses and we tend to wash our plows much more often?) Water, as stated above is critical for getting rid of "fresh" salt. Just my 2 cents!
