Safty shut down for a ele. fuel pump
Jaysad
If I install a ele. fuel pump on a ford 5.0 OMC, what do I need to do for a safty shut down?
Don S
Re: Safty shut down for a ele. fuel pump
Mercruiser uses an oil pressure switch to power the pump when running, and the start solenoid to power the pump when the engine is cranking over before starting.
Here is the wiring diagram and how it's wired in.
attachment.php
Jaysad
attachment.php
Don S you are the man!
?Does the S stand for Supersmart?
Thanks very much for all the info. you have given me!
