Sacraficial Anodes not deteriorating
ronjon444
I have a 1981 SeaRay - Merc 260.
I have noticed the outdrive & housing have started getting white corrosion on the edges and corners. My sacraficial anodes look like new and are not deteriorating. Do I have a grounding problem? The boat operates fine.
Any recomendations appreciated.
Tx ronjon444
Re: Sacraficial Anodes not deteriorating
take them off, clean them with a green scotchbrite pad, clean the area they bolt to, then re-install. usually they loose their grounding bond and they become coated with minerals in fresh water.
