S225TXRV draw tube and gasket part number
cousinabe
I have a 1997 S225TXRV. I just serviced my O2 sensor and need to get a new gasket and draw tube.
I've read many posts about draw tube changes.
Does anyone know the correct part number for the modified draw tube and gasket for this model#?
The 65L-11353-00-00 JOINT does not have a replacement part#.
cousinabe
Re: S225TXRV draw tube and gasket part number
kerplunk.... dropped it in the water.
no lectures please.
JUSTINTIME
oh, you tried the float test
ya my buddy tried that with my mac socket wrench last week
now i use Stanley tools when working on boats in water
rodboltw
the new number is 65L-11353-10-00
the gasket kit will depend on if the block has been changed since mid 2003.
the mid 2003 and below take a different setup than the mid 03 and up 3.1L motors.
draw tube remained the same.
the block can be easily I'd, look to see if theO2 holder mounting surface on the block is flat or has a raised round projection. flat is old number raised is new number.
cousinabe
Got my new parts and ended up snapping one of the bolts when tightening the O2 sensor holder to the block! UGH!
I did not take the two of three bolts off to see if I could grab the broken bolt with vise grips due to time constraints.
If I can not grab it, how would you recommend getting the bolt out?
Drill with ez-out?
Bolt #8 is in question.
http://www.boats.net/parts/search/Yamaha/Outboard/1997/S225TXRV/ELECTRICAL 3/parts.html
Thanks for any feedback.
JUSTINTIME
left hand screw bit then an extractor or ez out
cousinabe
I was able to grab it with the vise grips and get it out.
Thanks.
