rusty u-joints
ziggy
well, i been havein fun the last two days. winterizin....most depressing.....all was going well till i decided to remove the drive to lub up the ujoints and drive shaft and the likes....
well, here's what was stareing me in the face.
rusty ujoints...... and i suppose rusty grease on the shift slide...
wonder how the water got in.....typical question huh? kinda close inspection hasn't revealed the point of intrusion.....maybe i need to look harder.....where? or is it even relivent as to where?
since i don't know the history of the boat, i suppose i should do it all?
ujoint bellows, shiftcable and bellows, maybe shift shaft seals, inspect the ft. of the drive ft. seal for rust, when i get there.....oh, and guess what else feels poorly.....the gimble brg. ya can feel it so i guess it aint to smooth. so guess i'm up for one of thems too.......anything i'm missing as to what to go after?
Don S
Re: rusty u-joints
See, you knew the answer. ;)
ziggy
Re: rusty u-joints
thanks dons..............let the fun begin....... hope i can be on top of it prior to the snow....... i hate workin in a snowdrift.....
MikDee
Banned
Re: rusty u-joints
It don't look the bad to me? plenty of grease on the u-joints? minor rust, Jeez, that little could be from a little condensation. I'm sure they heat up when used, & cool down quickly when off, under water. If it's not a new boat, I'm sure a little rust is expected.
Don S
Re: rusty u-joints
True, but the rust is between the caps and the cross piece (needle bearings), and the grease should be IN the ujoints and gimbal bearing, not ON them.
Yea, I wouldn't touch it now either.
Just wait till it 90? outside and you have it in the water on the first day of the July 4th 3 day weekend when it starts really making noise.
Then you will have 3 days of nice weather to fix it. :)
thrasher
Re: rusty u-joints
Don, you should have put a smiley face at the end of that last sentence!!:)
ziggy
Re: rusty u-joints
to late now, made my decision.....
rubber and gimble brg. 1st while there's still hope of warmer weather......
so far so good..... i'm only bleedin a little bit.....:)
Don S
Re: rusty u-joints
Only bleedin a little????
Get busy slacker, that's only a 4 to 6 hour job, and it better be asolutely perfect in every way, and your bow light better not stop working.
Oooops, sorry, wrong rant............
But you really do need to pick it up a bit and be done before the weekend :D
