Re: Rusted on lug nuts
I use a 1/2" drive socket with a 3' pipe over the handle. The 90 degree angle of the socket makes it less likely to break the stud then if you used a long handled tire iron (which twists/breaks studs off very effectively). If the studs break off, so be it. Tap broken studs out with a small sledgehammer, then replace with new. <br /><br />Oh, Hold on.. at first you say lug nuts and later you say bolts... Are they lug nuts, or bolts? If it is lug bolts (not nuts) then I think you have bigger problems. If those break, then they'd be stuck in the hub holes (maybe forever ?)... maybe get em' out with good heat, but who knows, I haven't been there myself thankfully. I'd take more care not to break those if at all possible. But, I have stopped being too worried about breaking studs in my cars & truck... they're easy enough to change. New stud and new lug nut are $1.97 for the pair.... but again that's if it's a stuck nut, not a bolt.
