rust
string194
hi i am new to inboards can any body tell me the best way to flush the block for rust? the boat is a 1986 crestliner with a gm 4.3.it is not a closed system. thanks for any help:confused:
wire2
Re: rust
String, can't tell where you are, do you have a winter storage situation? If so, that's when most of the rusting in the block & heads occurs, if you just drain the water and then forget it. Much better to drain the water, put all plugs & hoses back on, then pump 50/50 water & antifreeze into it and leave it in there til next boating season. Then drain & save it, don't flush the anti freeze into a lake.
If you're trying to get the accumulated rust out of the block, there are caustic solutions to do that, (engine rebuild shops use it) but why do you feel you need to?
thrasher
Re: rust
Are you sure it's rust that you want to get rid of? Most Raw water systems suffer from Calcium deposits not rust!!
Gary
string194
Re: rust
i bought the boat as a prouject boat it has a lot of rust around water intake at block i am just trying to cover all my bases on fixing up boat i have never owned a in board . i live in central georgia thanks for all the info string194
Scaaty
Re: rust
Replace the rust and scale will just give way to fresh metal to do the same..(manifolds go every 4 years in salt--6-10 fresh...blocks...don't worry about'em)
Re: rust
Ayuh,.......... That Pure Bull$h!t...........
