Rust preventive
chumbucket
What is good for keeping rust in check??? Few spots on one of my motors ,would like to try and keep it living little more.
FlyBoyMark
Ensign
Re: Rust preventive
LPS #3 is the best s$$t.........#3, NOT #1 or #2. Leaves a nice waxy, greasy film thats water proof........ :D
Bob_VT
Re: Rust preventive
LPS-3 is the best. Leaves a waxy film and reseals itself. It is a lubricant available at most parts stores.<br /><br />Bob
Bob_VT
Re: Rust preventive
yes :)
crab bait
Re: Rust preventive
how is it compared to " boeing shield " it also is parafine wax type spray ...
oldboat1
Re: Rust preventive
If we are talking about a lower unit, I would be inclined to sand out the rust spots to bare metal, then use a zinc phosphate primer (or really any good primer). Repaint with an off-the-shelf spray in the appropriate color (Tempo has a variety of colors). I've also had good success with regular auto paints. I think the trick is to keep at the touch-up so the rust doesn't take hold.<br /><br />Here in Maryland, I've also used transparent anti-fouling spray made for lower units. This adds extra protection. If you don't need anti-fouling protection, use a clear coat for a similar effect. You can buy clear coat whereever you purchase auto paint.
FlyBoyMark
Ensign
Re: Rust preventive
LPS-3 should be used on all electrical parts and the powerhead...It meets mil. spec and is FAA approved coating for most all aircraft use.
D
DJ
Guest
Re: Rust preventive
Chumbucket,<br /><br />Sand down the areas and wash with 50/50 mix of vinegar and water. Then prime with Zinc Chromate. Add several coats of desired color.
Beernutz
Re: Rust preventive
I use Boeshield T-9 on the powerhead. Seems to work fine. I'm sure you know that this is merely a "preventative" treatment, not a "cure".
crab bait
Re: Rust preventive
that's what i'm gettin' at .. i wouldn't use that stuff to ' FIX ' rust with... maybe that LBS # 3 is a hole lot different
