Boat will idle and run but after fee mins loses fuel pressure and dies pump bulb and will fire back up and do the same thing need to get in water and ran before winter Thanks
Make sure that your tank is vented. Maybe loosen the cap to make sure. If that is not it then have someone repeatedly pump the bulb while running. If it keeps going then your fuel pump is bad.
