I have an 88 model suzuki DT 85.will not get over 4,000 rpm and runs hot after about 3 or 4 minutes of run time.gets out of the hole slow and is slow to reach 4k rpm.removed thermostat and entire bottom half is missing.where did it go? if it went into cooling passage and blocked them how do i get it out?water flow is pretty good at outlet and inlets are clean.what problem would cause lack of power and a hot running motor?carbs are rebuilt,timing checked,new plugs, compression 115,125,130.thanks!
