running out of fuel....
1984 35 hp Johnson, J35TELCRR
Starts and idles fine, runs at 1/2 throttle fine. At WOT, it runs out of fuel after a 200 yard or so run. If I keep pumping the primer bulb in the fuel line it does fine. Reckon it is the bulb? Or maybe fuel pump diaphragm? Thanks, BG12
kenmyfam
Re: running out of fuel....
Tank venting or fuel pump starting to fail in my opinion.
be more specific on the tank venting please. My cap is vented, and i have the vent open, because otherwise, when it gets hot it swells up like a basketball. Do i need to have the vent closed while running, and open when stored?
FAV453
You have a small portable tank with a vent in the cap? When running it should be loose allowing air in to replace the fuel leaving (keeping a vacuum from forming).
tashasdaddy
vent has to be open when running, store in the shade. it sounds like either a fuel pump failing, or the carb float needle sticking closed. disconnect fuel line at carb, turn motor over and see if the fuel spurts out. if it does, look at carb float needle. new carb kits, have a small spring, that attaches to the needle, and float, to pull the needle open.
jbjennings
The only possibility that hasn't already been mentioned---fuel pump, fuel filter, float needle-----is possibly the pickup tube in the tank (maybe it has a crack or split in it, causing it to suck air when the fuel pump is pulling the hardest.
Hope you find it, and I like my browning gold, too!:)
JBJ
thanks jbj, i am just North of you in AR.
the plastic fitting in the top of my tank seems loose. could that cause this prob?
kenmyfam
My money's still on the pump or float needle
took the carb off. needle and seat are clean, and seems to be closing and opening fine with air pressure. pump diaphragm does not seem hard. held it up to a light and could not see any pin holes in it.
what about the primer bulb in the line from the tank? a guy here at work seems to think that is the culprit.
jbjennings
Sometimes those check valves in the primers can be bad (often on the attwood junk from walmart) and that COULD be it, alright. Those checkvalves can cause some weird stuff when bad. I'd borrow a tank and hose and try that for sure!
JBJ
kenmyfam
I still doubt it's the primer bulb. My money's still on the pump.
well, it just happens to be a junk wal mart line... i know where i can get my hands on another one in the am. if thast not it, tuesday i will get a pump. thanks, BG12
kenmyfam
Good Luck and keep us all posted.
