running on muffs
aqrlan
When running on muffs how long will engine have to run before water comes out the pee hole
workerbee606
Re: running on muffs
Aqrlan my Yamaha will discharge water from the pee hole pretty much instantly when started on the muffs. Make sure you have the water hose turned on all the way. Also make sure the water intakes are cover completly by the muffs.
TwoRivers
My Suzuki DT 30 won't pee on the muffs. Pees fine in a barrel or on the water.
dpfundst
When I run mine with muffs, I have a bungee cord attached to ensure a tight fit. I also hold each "intake hole cover" with my hands whne I first turn on the motor to get it going...............usually see water in under 5 seconds..
jspriddy
My 25 hp 2 stroke Yamaha (2 cyl.) takes forever to run out the tell tale on the muffs. It starts immediately if in a tank. I seldom use muffs for this reason.
John
