Running Lights on Trailer
BeesWax
I want to replace the running light directly behind the wheel. The wire is pulled out of the running light due to a tire blowout. How do I remove ths running light?
Lurch77
Re: Running Lights on Trailer
We'd need a picture to give you a definite answer. But there should be some screws or bolts/nuts to remove the light housing. Possibly on the backside of the light where the wires go into it.
MH Hawker
Some have pop off lenses to get to the screws and so on .
BeesWax
With the suggestions I got here I tackled the problem again. I was able to get the lens of the running light off and replaced it with a new light. Thanks for your help.
