I have a little single axle trailer that I use to pull my boat. Recently, the fuse for the running lights started to blow on the Suburban. I backed my trailer into the lake without pulling the plug from my Suburban on Memorial Day, and that night on the way home I couldn't get the running lights on the trailer to work. The brake lights and blinkers worked fine. I found when checking that I had no power coming to the pin on the Suburban and traced it back to a blown fuse. I replaced it. The lights then worked. The next time I drove the trailer it blew again. It blew again when I took the boat out yesterday. I checked all the lights when leaving the lake, and they all worked (including the running lights). By the time I got home, the running lights were not working again.
My trailer has the four pin inline connector. I have an adapter that converts it to a round connector that matches up to my Suburban (6 or 8 pins). Does anybody have any ideas about how I can trace out what is causing the fuse to blow?
Thanks!
Thanks!
