I have a 92 15hp J15RENM. I freaked out when it started showing steam when the weather changed so took it to a marine shop. Tech repalced water pump and advised me that the prop shaft was straight. I was concerned because previous owner had hit a log. Tech also stated that I have a very fine engine with much life left if taken care of. I had fogged it for winter but today was so nice at 40+ degs and sunny so I took it for a cruise. Had some smoke at first then it ran like a dream. Smooth vibration, purring at wot, trolling 1.7 mph clean as can be. Then it changed slightly so I poped the hood and felt the thermostat housing: Too HOT to touch. HOT HOT. I let cool awhile then started, ran at wot for a mile, then felt the head: warm as normal, three second test. Water temperature reported at 45degs. At troll speed the tell tail is not strong, at plane speed the tell tail is strong. Is it normal to run hot a slow speed?
