Running engine out of water
bmxerbrett
I have a 85 thompson boat with a 3.8l omc. I bought the water "ear muffs" and have no idea where to hook them up. It doesn't have the water inlets on the bottom of the outdrives as I can see other outdrive do. Please help. Thanks
It's an OMC stringer outdrive
ne7800
Re: Running engine out of water
well i'm not familer with omc products but some pictures would help
Mrorak
look on the right side of the lower unit. There should be a hose hook up you will need female to female connector for my omc i dont need muffs. hope this helps
drrm123
If that's your boat pictured and it's a 1985 the sterndrive is from a 1972-1979 and there should be a attachment on the right side pivot cap where the water hose connects directly to with female to female connector, there should be a cap with a little chain on it unscrew that, no need for muffs.
