I bought a compression tester this weekend, and it did not come with any instructions on how to use it, and as stupid as it may seem, I've never used on before.<br /><br />I screwed it into the spark plug hole and had someone crank the starter. What is the correct reading, the first compression, or one after it has been cranked a few times? The tester is one that the guage will stay at the highest reading until you press the pressure relief valve and it zeros out again.<br /><br />Basically the first compression of the piston read 75, but i had her crank it for a second or two, and on the third or so time around it went up to 110. I did this on all the pistons, and got similar readings. Is this the correct method? Should I crank it until i get the highest reading? Or is the first pop on the piston the correct reading?<br /><br />thanks in advance...
