Running/Anchor Light Switch
I can admit when I goof and I did. My running lights and anchor lights stopped working so i started to troubleshoot the problem.
Like a fool(especially since I am a licensed electrician) I didnt check the circuit breaker first which happened to be bad, I disconnected the switch for the lights first and didnt label the terminals. Bad Idea. I have figured out with my continuity tester how the switch works but I cant figue out which wires are which and where they go. Can anyone help? Do you all have any wiring diagrams for the switch? Your help would be appreciated1
Mark
seapro
Re: Running/Anchor Light Switch
You could use a fused wire connected to batt. power to connect to wires and see which wire controls which light. Switch should power bow, stern and instrument lights in Run, Navigation position and stern light only in Anchor position.
Dave
