59 lonestar
- Aug 19, 2012
- 13
I've posted before and had great success thanks to the community. I have a new project that I've been researching and since I am very new, I don't know where to start. I've looked at the Electrical 101 sticky, and read some blogs, posts, etc., which has led me to more questions.
I have a 59 Aluminum runabout that I am rehabbing. I use the boat in a salt / fresh environment mostly for harbor / lake light cruising. My objectives are: 1) Install front Nav, and stern lights, 2) Install a bilge, 3) install a radio, 4) have a cigarette lighter port for iPhone power charging.
My questions (I?ve got lots, but trying to start somewhere):
1) Do I try to run these somehow off of the engine power (AC) or do I go directly from my main (or secondary) battery? I have read the http://www.uscgboating.org/assets/pdf/downloads/ELECTRICAL.pdf which showed guages and instruments like lights being run off of the AC. I?m not sure if I can run anything like lights off of the tach / gauge harness or if I should given an option. Boats, Yachts: Tips on Electrical System Use and Maintenance
2) Can I even run AC electrical out of my engine ? say somehow through my remote control secondary harness ? I have a side mount remote control from Mercury 881170A20 (which drives my Mercury 1995 35HP ELPTO), and it has an 8 pin (I think) ?tether for Tach?.
3) In the case of directly from a battery, how does that ever get charged ? or somehow should it be wired ultimately to the alternator so that although I am running on DC all the time, when the boat is underway, the battery is constantly being charged too?
4) I found a site ? EZACDC which seems to have a good looking solution to the task, but I just want to make sure I?m going about things right before grabbing a full system. Mostly, I want to make sure that 1) I?m not overseeing the any options with my existing control electronics hook up, and that 2) that I?m buying a system that will serve my needs, safely, and reliably.
Thanks!!
Thanks!!
