fullquartpress
- Jun 17, 2013
- 6
When I bought this engine, the toggle switch had no continuity in either 'run' or 'off' positions, so I connected the wires.
Then, when tracing the wires from the tiller handle's 'stop' switch, I found the bullet connector from the run/off switch unconnected, with a possible 'T' socket for another bullet connector.
I'd like to be sure where to re-connect it, and
is the 'run/off' switch supposed to be open, or closed, for the ignition system to spark?
The yellow/black wire green arrowed in the photograph is from the tiller 'stop' switch, and is connected to another yellow/black wire on the right side of the switch box.
Thanks for your advice.
is the 'run/off' switch supposed to be open, or closed, for the ignition system to spark?The yellow/black wire green arrowed in the photograph is from the tiller 'stop' switch, and is connected to another yellow/black wire on the right side of the switch box.
