Re: ruling out the kill circuit
Hi Dale<br />If you are refering to your 1976 85hp. The answer is no. You will have to jump the starter motor directly from a Batt, using jumper cables. Walker suggested this in a previous post. Also as Walker noted, if the motor does start using this procedure you will not be able to shut the motor off by conventional means. If I were you I would remove all spark plugs and ground them to the block for this test. This way you could see spark, and no chance of the motor starting.
