Rude & Johnny flywheel puller tools ?
CsBreeze
So, I'm trying to get my 71, 25 Seahorse to start. Fuel appears to be OK, but no spark shows on the tester. So is it true that I should NOT use a 3-leg puller ? The manual calls for (Special Tool #378103) and what the tool is that, that holds the flywheel to remove the nut ?
Thanks for help shipmates, I'm sure I'll be back with more questions !
PS: I bought an original '71 Johnson manual - a few greasy fingerprints & all, it was a great investment !
Thanks again !
boobie
NO three leg puller. Find the type pullers that are shown in your picture.
CsBreeze
Alrighty! - no 3-legger. What about the flywheel holding thingy ? Looking back, I see one guy said he used an impact wrench on the nut & it came right off - without holding the flywheel ! The service manual says, "remove flywheel nut using appropriate holding tool" - which would be what ?
The original problem was it quit acoupla miles off shore after acting up - THANK YOU SEATOW !
Honorary Supreme Mariner
Simple , with an impact you do not have to hold the flywheel.
CsBreeze
Yes, tightening will be the key - I can usually get ANYTHING apart ! :) So does anyone recognize the 'holding' tool he's using ? Or maybe, like any good mechanic, he whipped it up himself. And further, I have read here about trying to NOT pull the threads out of the aluminum flywheel - one more thing to be (afraid ?) of
-- And thanks for the input, Gents- I'm sure I'm not the first to do this or ask about it,, so your patience is appreciated.
Maybe use an old leather belt and a piece of 2X2 lumber to make a strap wrench.---I believe the threads in the flywheel might be in a steel hub.
F_R
No Title
The guy in the picture is using a flywheel rotating tool made for cars. Works for outboards that have gear teeth on flywheel. However, you can make your own strap wrench with a piece of wood and nylon webbing.
You won't pull the threads from the flywheel with proper tools and common sense.
CsBreeze
Great stuff guys ! Don't know why I didn't search youtube (tho I'm usually watching high seas videos there !)
I will report back when I've made more progress. Thanks !!
CsBreeze
So here's the hot wash-up:
Got a small puller from the chinese tool store and an electric impact gum on sale, them popped off the flywheel. I noted some small metal filings near one coil, and a shiney spot on the face. Also the paint looked burned !?!?! So I pulled the magneto plate off - AND WHAT THE HECK?! The front screw of 3, that the plate mounts to had backed out abt 1/4" !! I looked undr the mag plate and saw scratches where it hit ! So, without firther ado, I tightend the screw(s) and reassembled, 2 Pulls n a ROAR ! Up n running! The last gut who worked on it didnt tighen it, and I think when it backed out n up, it tilted the plate & missligned the magnet n coil - BINGO! No spark ! A long-winded replay, but thanks to all for your guidance and tips. I hope to repay the favor someday.
Smooth Seas and Tight Lines!
