RUDE carbs
lifes great
Ok, 1972 rude V-4 85 HP. MOD# - 85293R SER# - J04078. I do have the service manual for it, however it’s not showing me what I need to know. This has two carbs and a baffle to cover the carbs. On the baffle it has 4 rubber plugs with arrows that says low speed adjustments. Are these in fact the mixture adjustments? According to the book it’s not. It shows the high and low on the sides of the carbs. The screws in the front on the carbs seem to just be a plug of sort. First time on this engine.
Joe Reeves
Re: RUDE carbs
The 1972 Evinrude 85hp has brass fixed slow and high speed jets (non adjustable). The face plate with those rubber plugs are simply a carry over from a eariler model.<br /><br />Personally, if I had a "rude" carburetor, I'd smack it silly!
lifes great
Re: RUDE carbs
Thanks brother. Did that hurt like hell. So no mix adjustments on this animal? Also would you know the right T/T for this engine. It's an odd year and tought o find one. Thanks again.. :confused:
Melvin Hatcher
Re: RUDE carbs
Hey Joe,<br /><br /><Personally, if I had a "rude" carburetor, I'd smack it silly!><br /><br />How do you do dat and what does it do fo ya?<br /><br />DoferGofer :cool:
bubbakat
Re: RUDE carbs
Lifes great I have a rude in those early years and kept having trouble with the t&t so I ordered me one of the above mentioned CMC TILT & TRIM PT 130 and got it from iboats That thing is simple to hook up and wires are already wired so all you do is run control switch to front.<br /> great aftermarket product
lifes great
Re: RUDE carbs
Thanks guys, was thinking of that too the CMC. I'll never smack the rud angain, in this cold weather-- it hurts my hands...believe it or not, I'm in north Fl and it was down in the 30s my hands don't like it much...<br />Thanks for the info.... :D
