rude 150
mark.j
im new here,but i got a question ,what oil goes in a 1995 150 evinrude lower unit is it 80w90?
JB
Re: rude 150
Hi, Mark.
Welcome to iboats. :)
Gearcase oil (some people call it grease) is 90 weight. It is best to buy it in bottles or tubes labeled for that purpose.
Chris1956
Re: rude 150
Mark, You may want to use synthetic Marine gear oil in that gearcase. My '98 Johnny 150HP specifies the synthetic stuff, so either your motor requires it or they changed the spec sometime after '95 and before '98.
mark.j
Re: rude 150
how much oil does it take, and what brand should i use? thanks for info.
Chris1956
Re: rude 150
Mark, You need to get a quart, since the gearcase takes about 25oz. Pick up the gearoil and the pump set. They are made by various manufacturers, any of whom will do. Fill the gearcase from the bottom, until it flows out of the top hole and put gaskets on the plugs
mark.j
Re: rude 150
thanks again for info , i probably should get an owners manual for a 1995 150 evinrude, where might i find one?
