I recently replaced my MCM 260 engine with a new Vortec 5.7. Shortly after replacing it, I developed a leak in the straight 3" hose that connects the exhaust riser to the cast elbow. The connectors were old so I replaced them all on both sides of the engine with OEM parts (including the 3"-4" ones). I took the boat out and for a while it was fine, but when I opened it up for a period of time, the new 3" straight connector on the other side, ruptured. The rupture occured close to where the clamp is but it looked like a chunk melted away. When I replaced the engine, I switched to freshwater cooling and am using a 180 degree thermostat. Could the additional heat imposed by the freshwater cooling and thermostat change be the problem? Or is it possible that I purchased a defective rubber connector?
