I have just pulled the carpet from my boat. Beneth the carpet it left pieces of rubber and adhesive. I tried paint thinner on the entire fiberglass coverd floor to no avail. Is there a solvent for this purpose. Thanks! Rich
Yes there is, go to a floor covering specialist you should get what you need there however its not an easy task. Don't put that crap back in the boat either, use a proper marine carpet.
I use LACQUER THINNER, it's much better remover glue and stuff like that.<br /> Others here around the yard use lighter fuel first, because it doesn't evaperate as fast, they let it set for a while!<br /><br />NO SMOKING !!
