Since no one can determine the correct parts for my motor (Johnson Model # J130TLEOP):
Marineengine sent an incorrect kit, though it was close enough to use 2 (of 6) parts after modifying one. Modified the ring gasket which mates the carb to intake by cutting off one small circle intended for a bolt which does not exist on my motor. Did this for one of 4 carbs and since then have >50% improvement.
Rather than chance a 2nd incorrect shipment: Was thinking to use Permatex RTV to make a gasket to mate the plastic carb against the metal intake manifold. Thinking about leaving the current ring gasket in-place and adding a thin line of this Gasket Maker to make a proper seal.
I believe the current 15yo oem gasket allows air to pass causing a lean condition, hard starting and poor idle.
tia
tia
