Just bought a 1989 Oliver 1650. The boat ran not bad but slow out of the hole. The seller stated that it had the wrong prop on - a 4 blade 23 degree and it should be a 19 degree. Also could only get 3000 RPM max and 27 MPH. Changed the prop to a 19 degree 3 blade. Can now only get 2800 RPM and 28 MPH. It seems to bog down at full throttle and runs better at 3/4 throttle?? In neutral it will rev up to 5000 RPM no problem, but not in gear?? After a long trailer ride to its new home, it now idles rough and stalls at idle. Apparently I'm running last years gas. Carb rebuilt last month and had lots of water and sludge in it. Plugs quite carbonned up so I changed to new ones. After 5 minutes of running they were getting carbonned up again?? Could the RPM / Idle problem be sludge in the tank and filter??
