RPM's too low
jgm7739
Not sure if I posted this in the proper forum under this new format...but I hope I can find help!!<br /><br />I have a 1986 115 Yamaha, and just purchased a new Stiletto ss prop-19". When installed the rpm's @ WOT were only 4800 or so. After the first sea trial of the new prop I was instructed to raise the engine height on the transom, which I did. After a second sea trial my rpm's are still 4800-4900. Prior to this I was running at 5400-5500.<br /><br />What can I do to raise my rpm's to their maximum level as well as the boats overall performance.<br /><br />Initially with this new prop, I was looking to gain all around performance in speed, trimming bow, and hole shot.<br /><br />Thanks in advance
roscoe
Re: RPM's too low
In changing props, a lower pitch will give you better hole shot, a higher pitch better top speed.<br />You trade one for the other.<br /><br />I would drop 2 or 3 inches in pitch. This should give you a better holeshot and allow the engine to achieve higher rpm's, and increase top speed a little.<br /><br />Much better for your engine to have the engine reaching optimun rpm range.
