DixieBoatN
- Mar 17, 2009
- 41
I have a 1985 V150 XR2. I recently put a new foot on the motor due to losing the gears in my old one. Since I put the new foot on everything has been great. I was turning approximately 5500 RPMs at WOT. Not too long ago I went out on the lake one day and out of nowhere the motor would bog under throttle and die. I limped it back in and changed the water separating fuel filter and put a new inline filter on it. The bogging problem went away.
Ever since then I have been only turning 4500-4800 RPMs at WOT. It won't turn more than that and my top speed is down by about 10mph. I don't think the problem is fuel related because pumping the bulb does not do anything for it. I replaced both fuel filters again too because I noticed a bunch of stuff in the inline filter, but the problem persists.
The day it bogged down on me I tinkered with the throttle cable and it was idling high afterward. I have since corrected the idle problem by correctly adjusting the throttle cable again. The WOT problem persisted.
I have bypassed the oil injection system but don't think that would cause any issues and I don't recall the problem starting immediately after I bypassed it.
I had some problems with the arm on my throttle/shifter due to splines being worn on the shaft where the arm connects to the housing, but I temporarily corrected this by tightening the set screw until I can find a good set of controls to replace mine with. I don't think the controls are the problem, but I am not ruling anything out.
I have been looking for a factory service manual but have not been able to find one for the XR2... not even on ebay.
I am a pretty good automotive mechanic, but I am new to the 2 cycle world.
I suspect a problem with the ignition system, but have not found any fouled plugs and do not have the device to test the power packs. It seems and sounds like a retarded ignition, but I may be completely off of my rocker. I do notice when I go from idle to WOT as it runs up I hear it (not sure of RPMs because I have not watched tach during this) run the revs up and then drop back a few revs before topping out completely.
I did have a repeat of the bogging problem this past Tuesday when I was way out on the lake trolling and a storm started rolling in so I ran it wide open for longer than normal trying to get back to the dock. About 3/4 of the way back to the dock(25-30 min ride total) it started bogging and I had to back off of the throttle to keep it from dying. It died and after re-cranking a couple of times and babying the throttle, I was up and running again.
Any ideas on what/where to look are appreciated! If you know where I can buy a factory service manual without breaking the bank, I'd appreciate that too.
