CAPT.KEITH
- Sep 19, 2007
- 5
I need a expert,
I have a 1987 sea ray 340 in it is two MIE 340's My Starboard engine rpms are jumping about every 10 to 20 seconds when running above 2600 rpm,MOSTLY. I need 3200 to plane.
I switch to run off the other tank and was able to run at wot for about 15 min. b-4 I had to return to slip so I went out the next day and it ran about ten min. at wot b-4 the rpm's began to jump around.At this point it early Sep. and the gas is from last season.
tuned last season with wire's,coil,plugs,ignition modular,reman carb.
That being said the reman was no good till this season when I got the right one working all looks good but why is the engine jumping with my rpm's.
Just did a compression test all at 135 psi. all plugs except one looked the same the odd one at the electro was a light tan color ant electro was dry?
Thanks for your time on this matter,Capt Keith
