RPMs drop after 3 min on force
19732009
hi to all i have a 1988 fore 125 and after about 3 or 4 min i go from 5100 RMS to 3900 RPMs and will stay at 3900 to 4100 if i let the boat sit for 4 to five hours it will go back to 5100 for 3to 4 min and so on. i have good water flow and it is not to hot and i can hold my hand on the head and not to hot i have good spark with motor hot or cold replaced all fuel lines and fuel pump motor runs good at idle:eek: and half way. could it be jumping out of gear.
Smokepole27
Re: RPMs drop after 3 min on force
Does it bog down or the rpms just back off?
jaybirddog11
Have you done a recent compression test? Maybe try a compression test when you first fire it up and then after the problem shows up. How do your spark plugs look? Are they very old? My two cents.
jerryjerry05
Sounds like a fuel supply problem.Check the fuel vent then check for soft hoses.The Ethanol in the gas could be clogging up the system.
Change ols/soft hoses and go thru the entire fuel system.J
19732009
yes i have all new hoses and the fuel vent is ok next time i go out im going to do a compression test when the motor is hot.
