Re: rpm range
Is this rig new to him or has he had it awhile? Has it always done this or just started?<br /><br />Lets start with the basics. If pitch is the only issue at work we'd have to lose 8 to 10 inches of pitch to get near the 5800 rpm mark we're looking for. Start with a compression check. Then check spark. If these check out OK, look at the carbs. Perhaps a good cleaning and rebuilding is in order if you havent done so in a while or if its been sitting (has it?). Some new Champion (Q)L77JC4's would be nice too.<br /><br />Then if all this looks good, follow the sync-n-link proceedure in the service manual to make sure the linkages are correct. Make sure you are getting full spark advance.<br /><br />Dont overlook the possibility of trapped water in the hull.<br /><br />Good luck!
