rpm range
BENJA
I was just currious what is the rpm range at WOT in a 76 115hp, it has a 17 pitch prop
kenneymc
Re: rpm range
Seloc says 4800-5300. Not sure how that prop size will effect it if any at all.
schaiss
Re: rpm range
17 prop will have a GREAT difference in the rpm's you see at WOT especially if the prop you are using now has blades that are cupped. A prop with cupped blades will increase the torque on your engine and decrease the rpm's you might expect to see at WOT. If the prop you are using (the 17) was not the prop spec'd for that engine, you will NEVER see 5000 + rpm's!
