First time boat owner here. I bought a 1984 Mercruiser 120 IO on a 17' Glastron. The engine runs very good and we set the idle rpms to 500. My problem is I cannot get any WOT rpms.
It seems to max out at around 1800 or 22 mph. When I trim a bit I can get maybe 24. I have alot of trouble getting it to come out of the hole due to the lack of power. Takes a good minute. It did have old gas which I syphoned out and replaced. Checked the cylinders and all are operational reading 110-120. My oil pressure reads around 50 at 1800 rpms but dies down to almost zero when trolling at idle speed. I pulled the engine to replace the coupler over the winter and replaced all bellows etc. Aligned the engine, replaced the spark plugs, checked the points. Checked fuel filter and it looks clean. Put carb cleaner through it. Would rebuilding the carb make a big difference? Any suggestion would be appreciated.
Also if anyone can suggest a good tune up mechanic around Winnipeg, Manitoba???
Cheers.
Cheers.
