RPM gauges wrong readings
fotonews
Here I go again...
RPM gauges don't read 0 rpm when engines off, any ideas what could cause this? With engines running they work fine.
Bt Doctur
some gauges "relax" when unpowered and work normally when powered
wellcraft-classic210
Master Chief Petty Officer
I am guessing that's the normal power off state --Related to internal magnets, balance etc
Do they read 0 with key on & engine(s) off ?
fotonews
Thank you Gentlemen, I guess I will have to live with for the time being although messing around behind the dashboard I found a data cable 879981 A15. I have a feeling is to connect upgraded gauges... anyone has played with it?
GA_Boater
The cable is for SmartCraft gauges. Those doesn't look like SmartCraft tachs since they have analog hourmeters.
What kind of hookup is on the back of the tachs?
fotonews
GA_Boater, yes, they are analog gauges. Do I need one data cable for each engine or both info is in that one cable?
GA_Boater
Not very familiar with SmartCraft other than reading in the forum, but it's my understanding that the SC buss is supplied by both engines. I think with the cable behind the dash, it's more like the OBDII connector in cars/trucks. Diagnostic tools can be connected to the port to access the computer data for both engines.
It might be worth starting another topic about the cable. We do have more than a few Merc techs in the forum that know.
BTW - Have you had a chance to see if the tachs go to zero with the key on before starting the engines?
Here I go again...
Ayuh,.... Find a different detail to fret over,....
fotonews
GA_Boater, yes, rpm gauges go to zero when key on engines off. I guess I will leave it as is since when boat running they work ok except a minor jump on the needle once in a while. Im checking on the smart craft situation to connect VV Mobile with my IPad to have back up gauges in a digital format.
HT32BSX115
Here I go again...
Howdy,
Just about all automotive gages and many *new* marine gages are going to "Stepper Motor" type gage movements. Completely normal since the actual stepper motors are driven by an ECM or other type "computer" gage driver system.
They all pretty much will freeze in the last "level" , go to ZERO, or some other "park" position after shutdown. Then when the power is applied to the ECM, some will do a full-scale "sweep" and go to the commanded position.
All is good! Go boating!
Hey, Howdy Bill!!
Cheers,
Rick
achris
More fish than mountain goat
Haven't heard of steppers in tachos, but I could also be too old to care ;)....
However, the older marine gauges are all 'unsprung', meaning that the movement is ONLY done with the driver coil and not against a return spring. This is/was done so the 'bouncing' of the boat doesn't affect the reading (as much). With a return spring, it's effect will vary with the rise and fall of the vessel, making it (more) inaccurate... And unsprung gauges stay wherever they like once the drive/power is removed. What you are seeing is completely normal, and every boat owner/driver on the planet is presented with these unsprung gauges. Please move on, nothing to see hear folks. :)
Chris.....
